advanced typing test result do not show up, Hebrew language
גל קשפיץ shared this problem 9 months ago
Known
every time I do an advanced typing test in Hebrew it doesn't show me the result in my profile. if you go to my profile you'll think I did the test only 3 times but that's not true I did the test alot of times and scored higher and lower then what my profile is viewing
Comments (3)
76
Hello,
What average score do you get in advanced?
Do you have a lot of wrong words?
Please link your 10FF profile.
77
https://10fastfingers.com/user/1667046/ this is my user. the graph says my highest Hebrew test was 65 while I did 70 couple of times and it says my lowest is 62 while I did less on many occations.
note: this is only on the Hebrew Advanced test
87
OK thanks. You should contact the admin. I can't help you, sorry.
