Advanced typing test results displayed in normal typing test chart
Valentin Carette shared this problem 4 months ago
Known
I noticed that some results from advanced typing test are displayed in the normal typing test chart in the user profile.
There is a way to see it actually: by comparing the score to the number of words typed. In advanced mode, the words are longer, so with fewer words you get a higher score than in normal mode. ;)
But it will be simpler and faster if you take a screenshot and show me where the results are not in their place.
Comments (5)
18
Hello,
Can you please link your 10FF profile?
19
I see nothing wrong on your profile.
17
Some results are in the wrong place, you can't see it if you don't know which one are supposed to be normal or advanced.
22
